So I’m assuming you want a large freeway page to put your content?
If you goto the Inspector panel you will see two fields W: and H:
You can enter your page dimesnions here and add content. Freeway will crop the height of the page to your content.
Nathan Garner
Creative Director
Austin Wells Design Limited
One Elmgate Drive - Littledown - Bournemouth BH7 7EF
t 01202 301271 e email@hidden w http://www.austinwellsdesign.co.uk
Member of NAPP
On 28 Jan 2010, at 13:44, David B wrote:
Okay, I’m embarrassed to ask this, I can’t find it in my handbook, although having said that I am probably looking right at it.
I want to create a freeway page that’ll scroll endlessly (well, within reason)
I cannot believe I cannot solve this. Probably a precurser to some kind of mental problem…
Are you talking about the JavaScript trick where only a screen or
two’s worth of content loads, then as you scroll near the bottom of
the page the server fills in some more content? I’ve heard this
referred to as an “endless” page.
If so, there’s no direct way to make this in Freeway, but there are
plenty of JavaScript tricks in the Prototype library that Freeway 5
includes which would make it a relatively simple thing to build.
within reason)
