Have gone to Actions Forge and Tim’s site and all I see is the “PHP_Form_Action”. Is this the one you are referring to and if so is there documentation as to how this would be used to protect a page?
I have a copy here of PHP Basic Authorisation, written in 2001 and
last touched in 2003. I’ll send it to you privately, and remind Tim to
post it at ActionsForge.
On Apr 18, 2009, at 4:24 PM, TeamSDA wrote:
Hi Walter,
Thank you for forwarding the action. Have a couple of questions.
01 - The action has a file extension of “.act3” which is different from the other actions I am using in Freeway Pro 5.
02 - The setup in the actions panel seems pretty straight forward but I don’t see a place where I can customize the user logging prompt.
03 - After I upload the site and go to the page that has the action applied I get a safari type login prompt, enter the user name and password and the page reloads blank with the same login prompt. The top of the prompt reads
Older Actions have this extension (this is what Freeway 3 used).
You may change it to fwaction and nothing bad will happen. 2) The
login prompt is a standard HTTP Basic Authentication dialog. It is
drawn by the user’s browser, and if the user is set to a non-English
operating system, translated for free. 3) You may be using the CGI
form of PHP (fairly rare) as that hosting setup does not properly set
the PHP_AUTH_USER global variable. That could lead to the re-login
thing you see. I’d have to see this running on your server to diagnose
it further.
On Apr 18, 2009, at 5:25 PM, TeamSDA wrote:
Hi Walter,
We have uploaded a page using the “PHP-Basic Authorization” action as well as an error page. I have also contacted Softpress to try another direction. Would prefer your friends Action though as it is much more straight forward.
Also the error page does not load if an incorrect user name or password is put in, is this due to the issue in item 3 from my above thread?
I am eMailing the link to our server for your review as requested,
Basic Authentication does not work the way you seem to think it does.
It’s baked in to the HTTP protocols, not something you layer on top of
a site. Your server sends a header to the visitor’s browser telling
them they need to authenticate. The visitor’s browser displays a
native login and password dialog, the visitor fills that in. If the
authentication was successful, then the page is displayed. If not,
then your server displays a generic error page for the specific 401
(Unauthorized) error. If your hosting provider offers a way to edit
the server-generated error pages, then you can do that following their
instructions. On some servers, this can be as easy as making a page
and giving it the filename 401.html.
thread?
OK This makes sense but if I am uploading the error page manually to our server what is the error page pull down menu for in the action. Also can you have a look at the other issue from our previous thread?
Previous issue
This doesn’t look like it’s part of Tim’s Action to me. That Action
just makes a 401 header happen and the browser does the rest. Is it
possible that you have another system working as well, maybe something
you uploaded once and tried and forgot was there?
The Error Page thing is nothing I ever tried using, I just tried it,
and realize that that part of the Action appears to be broken. Tim
hasn’t touched this thing since 2003, but if he gets a chance, I’m
sure he can fix it.
Thank you for letting Tim know about the bug as this would be a great action to have working, error message and all.
I have deleted the contents on the server several times and the authentication still does not seem to function. It just keeps bouncing back to the login screen with the message as listed above. I do have some other PHP scripts on other pages but those are totally separate and don’t link to this test PHP page. Have also tried this without uploading these other pages. Any ideas as to why this is not working?
Thanks to Walter for pulling the PHP-Basic Authorization action out of
the archives and sending to TeamSDA. I wrote the action back in 2001
for a project I was doing at the time and although I kept it up to
date for the next couple of years it hasn’t been tested for a while now.
Looking at the code the action creates I can see that it should still
work although it is only going to protect a single page, rather than a
whole folder, at a time. To protect a directory I would suggest using
an .htaccess and .htpasswd file.
Different browsers interpret the incorrect details in different ways.
For example Safari will just keep asking for the username and password
until the user clicks cancel. On IE the error page (or message) is
displayed as expected.
I’ve not made the action publicly available until I have the chance to
fully test it as I’ve little time to firefight any issues that might
arise.
TeamSDA , if you want me to work with you to revise the action to suit
your needs then please feel free to get in touch.
On 20 Apr 2009, at 10:49, TeamSDA wrote:
Hi Walter,
thread?
Thank You, Team SDA
Express & Pro.
Spam.
Thank you all for your input to us regarding this original thread authored by Joachim Levin. To better address our needs we have started new thread called “Secure Client Login Action” below is the link.
