I need help deciding which version of Freeway and actions I need to buy to develop an online shop. (Looking at various help pages I’ve a pretty good idea but need to make sure I’m doing the right thing.) I’m new to Freeway as I wanted an easier than Dreamweaver app for the client to eventually take over site maintenance and now I’m a convert. Yay! I started in Freeway 4 Express but in order to have shopping cart actions (already signed up to WorldPay) and not very straightforward shipping calculations I needed to upgrade to Freeway 4 Pro. Correct? So I bought this with the free upgrade to Pro 5 (haven’t converted the site from Express4 yet). I opted to go with Mal’s commerce because of the actions available and opened an account. I now see that shop actions are available with Freeway 5 Pro AND Express5. Do I still need to buy Mel’s shop actions or is it the same action? Can my client use Express5 to maintain a site created with Pro4? What is the best way to go from here? The site has been kept very simple and easy to use - the only complication arising so far is from shopping cart integration. Actions seems to be the way to go but did I need to upgrade to Pro? Would greatly appreciate the benefit of all your experience with this. Thanks in advance, Neil.
NB. I was test purchasing with some of the featured shops on Freeway site and if on the cart page you hit reload (one of the images wouldn’t load) the purchased item is added and calculated again. Now, you could say don’t hit the reload button but this doesn’t seem right. Does it?
