I need some help, please. I have a client whose website I have biult and he now wants a Prestashop Ecommerce page for a take away menu. DO NOT need a full website. Will also have to have ICRTouch add-on. Website designed in ‘Freeway’, Prestashop will be on same server.
hi gray,
what is the problem exactly?
presta or that you dont know how to design it?
it is not so hard to make a shop. the basic is more or less css and php.
if you make one in a subdomain and make a menu change in your website to direct customers to it, it is quit easy to do.
if you first make that shop in a subdomain ( just an example) you dont have to make that menu change until you are happy with it.
in presta there are quit a few templates you can easy change in their css to make it as fit to your design as much possible.
i’m affraid i’m more zencart lover than presta, so there i can not help you very much, but basicly the presta shops are not so much different and the forums are very helpfull.
I would suggest to make a test shop first on a local server of your own and test it.
it is realy not so bad.
and ask there for advise!
make a database first, install ( or let your host install it for you) and do a demo shop!
good luck!!
