You can set its fwEnabled to false, which will make it dim and
unchangeable. You should test to see if it is a usable parameter after
that point. You could also set its fwVisible to false, which will hide
it, again, I’m not sure if its value is readable when it’s hidden – I
seem to think it is, because I’ve had to work around that in other
cases (where I would prefer that it not have a value if the user can’t
set that value).
On May 27, 2009, at 9:36 AM, max wrote:
Hi everyone
Does anyone know if there’s a quickway way to hide a checkbox in the
action interface like you can with field items eg like this:
Thanks walter… I was just being lazy. I was hopping I some one would know something that will just make it invisible by the flick of a switch (var) in its name, but if thats not the case then I might as will do it properly…
cheers max
