Hover text problem on PC
I’m not sure if I “hover text” is the correct description, but my problem is that when viewing my websites on PCs, text appears when the mouse stays still for a few seconds. The text is the name of the graphic that is below the mouse. This doesn’t happen on the Mac.
Is there any way that I can stop this happening?
Only by removing all alt text from your images - see the Inspector
palette. This isn’t a particularly bad thing to do with images that
are purely decorative, but anything at all informative should be
tagged to help with accessibility.
But don’t get too hung up on this. It is normal behaviour on PCs, so
PC users are fairly used to it.
k
What you are seeing is a ‘tool tip’ and controlled by the ‘Alt Text’
found in The inspector. Select the graphic and in the Inspector select
the third tab from the left. You will see a check box next to to ‘Alt
Text’, which you can uncheck. Better still, to help both those with
graphics turned off in their browser and influence search engines,
leave the box checked and add a brief description of the graphic - it
will help with screen readers, too.
HTH Colin.
Your reactions are obviously faster than mine, Keith. But then you
have the advantage of relative youth :wink:
Colin.
palette.
you have the advantage of relative youth :wink:
Meaning my sons are still young? :wink:
(Thinks: does 17 and 21 count as young? heh.)
k
With six grandchildren already - YES!
Colin
(Sorry to hi-jack your thread, David).
Thank you both for the replies. I am producing a site for my brother-in-law and he asked my why a message comes up on his PC that says “MediumGreyBackground” when he hovers the mouse over the page.
This is not a particularly useful bit of alt text I’m sure you’ll agree! Perhaps I could just remove the text from some images and improve it on others? A long-winded job. I was hoping there was a button that changed this for the whole site…
Why can’t everyone have Macs?
on others?
Exactly the right approach.
A long-winded job.
Moderately. You should find that it isn’t quite as bad once you get
going, but it will be a bit long-winded. Perhaps click the Site
panel’s title so you focus on one page at a time, showing every item.
You can see and select your graphic items from there. Move the
Inspector palette over next to this panel and you should be able to
dance through things fairly Astaire-like.
That of course is the RIGHT question. :slight_smile:
k
On 26 Jan 2009, at 15:50, Keith Martin wrote:
Move the Inspector palette over next to this panel and you should be
able to dance through things fairly Astaire-like.
In page mode like that you can Option-click item titles to edit them.
No need to shimmy the Inspector over.
;o)
Heather
Unless you wanted to edit or disable the alt text of course… :wink:
k
Hi David,
What you are seeing is, IMHO, a bug in IE in that it renders the alt data for
the image if no title attribute is present. Rather than deleting your alt data
(as Keith mentions this is really quite useful to have) simply add an empty
title attribute to the image;
title=“”
Select your image and select Extended from the Item menu. Making sure the IMG
tab is selected press the New button and enter;
value:(nothing. leave this empty)
Press the OK buttons to exit these two dialogs.
The browser will take this text over the alt data and seeing that it is empty
will simply not render any tooltip for the image.
Quoting David email@hidden:
Extend Freeway the way you want with FreewayActions.com
http://www.freewayactions.com
There’s a set of Actions to automate this solution here:
http://actionsforge.com/projects/view/56-fix-ie-alt-tags
an empty
title=“”
Thank you Walter, and all others, what a great list. Not only do I have a quick fix, but I also now understand what is going on! Brilliant.
