Note that if you do this, leaving off the http: prefix means you won’t be able to preview this on your Mac. The reason why scripts are distributed in this manner is so that they can work around having to provide separate instructions for https: (secure) hosting.
On Apr 7, 2013, at 11:47 AM, DeltaDave wrote:
This code really is two sections
Section 1 is the iFrame code to display the mp3 stuff.
The 2nd is to display the title and artist - which you can add yourself.
Brilliant - many thanks for that. I linked the widget in a ‘text link to new window’ - is this best thing to do
Couple more questions! Why do I just copy code up to ‘standard’ - do I not need the 2nd half of code and secondly - how do I display title and artist, would this be just a link to a playlist.
None taken!
Its just that, as a code virgin, I wondered why you needed just half of the code. To compare, I have now inserted all the code and there doesn’t appear to be any difference.
Thank you for your help.
