I too would really appreciate an answer as to how to make Exhibeo Slide work responsively in a Backdraft environment as I have tried all the advises and instruction thus far without success.
Using all the latest Freeway,Backdraft and Exhibeo software - have referenced the latest info from Calebs Backdraft site.
What I have been doing is copying and pasting a “oneWrapper” framework module which contains as standard an image and some text.
I have then simply deleted the image and the text items ,clicked within the “oneWrapper” module and inserted the Exhibeo action and associated it with the exhibeo file.
I have then , using the item handles expanded the file to fit within the html wrapper and input the extended attributes as advised.
When I publish and test ,the exhibeo simply does’nt respond.
There was one occasion when I briefly got the slide to work by accident (sadly a day earlier and Freeway crashed without saving)
When I did get it working I recall having to make additional changes.
I believe these changes were attributes in the Inspector palette from “Fixed” width to “Fixed%” I seem to recall.
Have you added the action as an inline item? To do this, you will need to double-click inside the module so that you see a blinking text cursor, then in the menubar, go to Insert > Action Item > Exhibeo Import. If it’s not an inline item, then it won’t flex.
