It’s working! Thank’s a lot!!!
That is sooo good! Exactly what I wanted.
Mélissa
Mélissa
Great! Post a link so we can see your hard work!
Hi!
My website is “melissameylan.ch”
I don’t know why it’s not working at the moment. I tried to put the last version of my layouts on the server. But something is strange. When you go to my webpage, you see “Apache 2 Test Pagepowered by CentOS”…
I don’t understand what happend. I did it in the same way as usual, with filezilla… Maybe someone can help me…?
Thank you!
Mélissa
As the page says “let the administrators of this website know that you’ve seen”
Report the issue to your hosting people
On 5 Jan 2011, at 21:28, “melissa” email@hidden wrote:
Hi!
Thank you!Mélissa
Okay, thank you.
I wrote my administrator… And wait for the answer.
Mélissa
Melissa, double check that you have uploaded your site to the correct folder on your server - usually something like htdocs or public_html - and that your home page filename is preferably index.html. Your Control Panel should tell you the correct FTP address and if you copy that to Freeway in the File menu > Document Setup > Upload tab, Freeway can handle the uploading and file management without the need for ‘filezilla’.
HTH Colin
On 5 Jan 2011, at 21:28, melissa wrote:
Okay,
Thank you for your advices. It’s working again!
So now my only “last” problem to solve is my homepage.
I would like that the name of the projects (which are represented in paths) become the same color than the path itself when you overfly it.
And as well, when you overfly the name of the project, the name itself and the corresponding path become the right color also.
Maybe it’s better to see my homepage on my website to understand what I mean…
melissameylan.ch
Mélissa
Not knowing how you created the original rollover effect on the paths I cannot duplicate that but what I have done is put together an example using Rollovers on the Menu items to Target show/hide the images
http://www.deltadesign.co/odds/melissa.html
It may be that having the rollover on the pics/paths as well is not easily done.
Thank you, that’s exactly what I’d like to do.
How did you do this? Which action? How can I do the same?
I did the orginals rollovers effects with normal rollovers.
I drawed the boxes with the “polygon clickable area” (maybe the tool has an other name in english, my freeway is in french…) to get rid of the square boxes around each path.
And I had one black path and one with color.
But this still don’t work very well.
Mélissa
What version of FW are you using and I will send you a file but you will need to let me have your email address - but remember if you post it to FWT it will get obfuscated.
So use the format melissa(at)melissameylan.ch
Okay thank’s!
I’m using freeway 5.5 pro
And here is my adress: email@hidden
Mélissa
Ah shit, yes, so here is my adress : melissa.meylan(at)bluewin.ch
