Thanks for posting this. I was able to add a new page called
index_da.html, republished, and saw the new page in the one (and only
one) index.var. I did have to hold down Control and force Freeway to
Publish Everything in order to see the new language, but that’s more
an issue with Freeway and Folder Actions than anything you might have
done in laying out your site.
I don’t see anything wrong with your site per se, but the real
problem is that you have your Freeway document in the same folder
that you are publishing to. This type of Action needs to store
temporary files next to the document while generating external files,
and publishing into the same folder messes with that. The Action
tries to save a file called index.var in the temporary folder (which
is always the same folder as the Freeway document itself) finds one
already there – the previous copy generated during the last publish,
and so increments the name of the file. You will get similar hard-to-
predict behavior if you use images in your layout from the Resources
folder of the same site you are publishing. (A sort of M.C. Escher
exercise if you think about it.)
Try laying your project folder (on your disk, not the server) out
like this:
/Project Name
freeway document.freeway
/Media -> all the extra stuff you need, pictures, movies, etc.
/Site -> where you tell Freeway to publish
Freeway will have a much easier time of it that way. The Media folder
is not specifically required, but it helps when you need to find
something later for updates. You can also get this sort of
“preferred” disk layout by selecting File > Archive from the main
menu. Freeway will magically collect any external files you have
referenced in your document, place them in Media, sever all links to
the original art and re-link to the copies in the Media folder, and
publish the site into Site.
On Jul 21, 2008, at 3:52 AM, tobiaseichner wrote:
I was a bit too fast… now the indexa.var file is there again.
This is what I did:
Creating a new project adding the page action and three pages
(German, English, French).
Generating the site to give it a try.
Adding the alternative page index_alternative.html. Now I have
two .var files - index.var without the new entry and indexa.var
with the alternative page entry.
For you to check it out, I uploaded the project here: http://
TOBIAS EICHNER IT + CONSULTING - Information Technology Is Our Universe !
I’m using FW 5.1.2.
