I am trying to separate two items but cannot find a way to do it.
In the Inspector, the layer box is checked but not the locked box. I have tried to uncheck layer but it doesn’t do anything.
Help?
waltd
(Walter Davis)
March 1, 2012, 4:05pm
2
Have you tried Item / Ungroup?
Help?
It does not give me that option. “Group” is listed, but it is subdued.
Can you contact email@hidden and send them a your Freeway document with a short description of the problem? We’ll then be able to take a look and see what’s going on.
Cheers,
Chris Sowley
Design Monkey & Problem Solver
T: +44 1993 882588
E: email@hidden
Freeway: You create, it codes
