how-to drop-down rollover menus?
I feel certain that there is a technique within Freeway Express to create a rollover dropdown pane which has a list of items which can then be selected and clicked on, but I cannot figure out from the action instructions how to do this. Can someone point me in the right direction for this? Maybe a page in the users guide? or a link to instructions? Help much appreciated!
Problem solved. If I limited my search to “create a dropdown” then it came up with the right info! Page 353 in the Freeway Reference was my answer. If the word “menu” was included, the search engine found all the wrong things…
