How to keep text from going to edge of text box?
Is there some way to control the edge spacing on text in a text box? When I draw a box, the text is right to the edge. i would like to add a couple of points of open area all around so they text does not look like it is squeezed.
Thanks.
The easy way is to add some padding.
Click your text box. In the Inspector - click on the top left 1st icon. At the bottom of the Inspector you will see “padding”. Experiment with the option there.
