SkipII
(SkipII)
June 28, 2009, 2:20am
1
I thought there was some way to do various styles of gradients in a graphic box – such as having an area in the middle that is than the sides, etc.
I have searched through the entire reference guide and do not see anything.
If you are using Pro then there is an action called Fill Master that will do this for you.
Select your graphic box and add the action to it - Item>Actions>Fill Master and then set your parameters in the Fill Master Action Pane
IanB
(IanB)
June 28, 2009, 11:34am
3
The movie Video Tutorial 1 http://www.softpress.com/support/usingfreeway/ illustrates how to get started with Freeway. It shows how to colorise a text box. The same method works with graphics boxes:
More useful movies can be found by clicking the Video Tutorials link on the Using Freeway page:
http://www.softpress.com/support/freewaymoments/
Freeway’s graphics effects, including gradients, are described in the Graphics FAST Pack User Guide (PDF). Download it from:
http://www.softpress.com/support/usermanuals/
