How to reference a CSS File in FW Pro 5
Hi,
How can I reference an external CSS file so that’s it available to the whole web site, so that I have the following set-up:
Thanks.
T.
You could just copy and paste your CSS link by selecting the Master page that is going to be needing the link and going to “Page” and select “HTML Markup” and then make sure “Before ” is selected and copy the code in there. That will then add it into the published files in the site folder, but you won’t see the Freeway layout look any different on screen because of the added styles until you publish and look at it in the browser.
You can import a style sheet into a freeway file. Choose Edit… Styles, click on the little cogwheel and you’ll see the “import” option.
