This symbol is a picture of a lock or a certificate, right? Just place
the picture on your page in Freeway, same as you would any other
image. Otherwise, if the server is connecting with the browser over
port 443, the browser will do whatever it does (little lock icon,
yellow background on the URL, etc.) to indicate that the connection is
secure. You can’t do anything to make the browser do that part if the
connection is not actually secure.
On Nov 11, 2009, at 11:51 AM, julie maxwell allen wrote:
Walt,
I took the squiggles out and it worked like a charm
place the picture on your page in Freeway, same as you would any
other image. Otherwise, if the server is connecting with the browser
over port 443, the browser will do whatever it does (little lock
icon, yellow background on the URL, etc.) to indicate that the
connection is secure. You can’t do anything to make the browser do
that part if the connection is not actually secure.
Walt,
Could you post it here? Use the same trick I did (four tildes in a
row, all by themselves on a line, then your code, then another line
with four tildes) and then it will stay properly formatted in the Web
view.
On Nov 11, 2009, at 12:17 PM, julie maxwell allen wrote:
I just have the HTML code… not the picture.
browser over port 443, the browser will do whatever it does (little
lock icon, yellow background on the URL, etc.) to indicate that the
Walt,
Web view.
(little lock icon, yellow background on the URL, etc.) to indicate
that the connection is secure. You can’t do anything to make the
browser do that part if the connection is not actually secure.
Walt,
It’s up to you (or your client) if you want to advertise for GoDaddy
like that. But if you do, just paste this into a Markup item and place
it on the page where you would like the seal to appear. You’ll have to
experiment with it once you upload, you won’t see anything WYSIWYG in
Freeway except an empty box with a little < H > in the corner.
Web view.
indicate that the connection is secure. You can’t do anything to
make the browser do that part if the connection is not actually
secure.
Walt,
place it on the page where you would like the seal to appear. You’ll
have to experiment with it once you upload, you won’t see anything
WYSIWYG in Freeway except an empty box with a little < H > in the
corner.
line with four tildes) and then it will stay properly formatted in
the Web view.
secure.
Walt,
Essentially you could make one of your own - thats what GD did. I am sure a Google search for Padlock images will turn up something suitable. This is a Network Solutions one - not suggesting you use it but is certainly a lot more subtle than the GD one.
The client does his blog site w godaddy -and stuck w them… his choice
not mine… I cringed when he told me…
I am going to help a friend w a site for his radio show and it is
parked on godaddy - i told him it needs to be changed… and he will…
