iDisk Replacement?
I frequently used Apple’s iDisk to transfer files and images to and from clients. Now that iDisk is gone, what service do you recommend that has the same functionality?
It’s not quite the same, but Dropbox is similar.
I’m going to do the “I’ll invite you to get more free space” game. Others might.
http://www.dropbox.com
Heather
iFlickr http://www.flickr.com/photos/snaptophobic/
Blather and Bluster http://snaptophobic.posterous.com/
iTweet http://twitter.com/Snaptophobic/
¬_¬
Thanks Heather. That looks pretty good. How much does the Dropbox service cost?
Oops! Never mind. I found it: Upgrade your plan
You get a fair bit of space free (I use it free, as I am a registered tightwad), but I see you’ve now found the prices for paid-for stuff.
=o)
Heather
Imagic Design * Good Design - No Compromise
http://www.imagic-design.co.uk
Twitter @Imagic-Design
T: 01634 864017
If you have a one-off file you want to send to someone, rather than a project folder you want to have synched between multiple computers (the Dropbox specialty), you might consider my free Fling app: http://fling.walterdavisstudio.com
=o)
Heather
T: 01634 864017
You can also get creative (and technical) with free Dropbox. I use symbolic
links to synchronize files between my laptop and desktop. Works sweet.
Well, I could probably get creative, but I’m not sure I could get technical. :slight_smile:
