IE PC rendering FW4 output OK, not FW5
Hi, when I generate a site from FW4, a particular table renders OK in IE PC (v5.5 or v6.0), but when I generate the same site using FW5 the table appears all squashed to one side.
The FW4-generated version is at:
http://www.fouracretrust.org.uk/examples.html
The FW5-generated version is at:
http://www.fouracretrust.org.uk/testarea/examples.html
All looks good in Safari and Firefox Mac.
Any ideas?
The site was originally created using FW3, so maybe there is too much ‘baggage’ carried over from that. Do I just need to bite the bullet and re-do the site from scratch in FW5 using CSS layout?
Cheers,
Stewart.
Not to worry. I have just added a row at the bottom of the problem table, full width, and added a graphic box to force the table to that width.
Stewart.
