How can I set my iframe color to a black background? I tried the extended
option but must not be doing it right.
Bill
Bill McCarroll
Website: http://billmccarroll.com
Twitter: http://twitter.com/billmccarroll
An iFrame is really just a window onto another page and the content is determined by the content of the other page.
So I think the simple answer is - you can’t.
Thanks David, not the answer I wanted but you may be right.
But before the frame renders, it shows as white against my black background
page. The source page in the frame is also black (my photo gallery). Just
trying to make it seamlessly black through the entire load.
No way to do that?
Bill
Bill McCarroll
But before the frame renders, it shows as white against my black background page.
OK then try this
Click on iFrame - Item>Extended
Div-Style
Value: black
But also, and I am assuming that this is a Lightroom gallery?, have a look at the direct link to the gallery and see what you get when you load it outwith the page with the iFrame on it.
I think that does it Dave, still seeing some white rendering but much better
than originally.
Bill
background page.
OK then try this
Div-Style
Value: black
List Options | FreewayTalk
Bill McCarroll
Thats why I suggested you to look at the direct link to the Gallery page - not in the iFrame - in case it is evident there as well and a quirk/setting of the Gallery that was causing it. Have you a link you can post?
Glad it is better anyway.
