Can anyone tell me how to import text and preserve the hyperlinks?
Hi Graham,
There are a couple of ways you can do this depending on what format your original text is in. If the text is in an HTML format then you can simply add it into your page as a markup item (Insert > Markup Item…). Alternatively you can use the Auto Link Action (Auto Link - ActionsForge) to hunt and auto link addresses in the text. You will need to add your own markers in the text for the Action to pick up on.
Can you post a link to the text you want to include so we can see how you can best include this?
FreewayStyle.com - Free Freeway templates and parts to download, use and explore - http://www.freewaystyle.com
Hi Tim
The text is in an .rtf file created with TextEdit.
Hi Graham,
The easiest way to do this is going to be to export the RTF document to HTML (File > Save as…) and to edit this to remove the bits of the HTML page you don’t need.
This will get the raw text and links into your page. If you want the styling as well you can copy the CSS styles (also in the original HTML file) into your Freeway page.
