Hi
Having a problem with the indent feature changing the font when applying to a body of text.
I have set up a style sheet for the body text and also for the indent.
When I apply the indent to bullet point text, it views OK in freeway, but as soon as I preview it changes to Times in black as opposed to my style which is grey Helvetica.
Check and double checked and deleted the text box and started again, still the same.
What am I missing?
Is it online somewhere Mike and we can look at the underlying code and see what is going on.
And I assume that you are referring to the indent that is applied when you make it a list item. Does the style that you created include the list Tag?
But if you can post a link we can see exactly whats happening.
Are you making a “list” item or just modifying the left margin of a paragraph in say 20px? There’s a big difference in styling.
If you’re indenting and making a list item Freeway will create a temporary style for it. You could find it and edit it, add the font.
David Owen
http://www.ineedwebhosting.co.uk
On 26 Jul 2014, at 14:52, “Mike Thornley” email@hidden wrote:
Hi
What am I missing?
