insert a quicktime animation
hi everybody, i wanna try insert a quicktime animation, formed with text and images, created with keynote.
is it possible?
i like quicktime causa the animations created with keynote maintains their appearance and transition effects.
I just don’t know how to insert 'hem in freeway pro.
thanks
bests
nicola
If you export from Keynote as a QT.mov file then it will be treated like any other movie in FW
Draw an html box on your page and then import your QT movie or drag it from the Finder onto the page.
Now if you want it to work like a presentation then you will have to set these things up in Export settings in Keynote.
I would be careful though as files created like this from Keynote can be rather large.
A sample file in Keynote of 580k exported as a 10Mb mov
ok i’m gonna try right now…i didn’t expect things so easy…!
as the Mb, you say that a qt file is too big ??
thank you so much.
nicola
All I am saying is that be aware of the finished movie file size - too large and it will take a long time to load and people will leave rather than wait.
If it is too large a file then there may be better ways to reduce its size or even use Flash which generally is better at keeping file sizes down.
