Hi Nick,
I bought Sketchpad last night when I searched for diagram tools on the iTunes Store. I also own SketchBook, which I bought last year looking for the same types of apps, but I’ve used it a total of 2 times when I realized it was not meant for how I wanted to use it. However, Sketchpad is almost exactly what I was looking for - extremely straightforward, easy-to-use, and very flexible (the grouping feature and being able to save your own shapes is awesome). It would be the greatest phone-based diagramming tool EVER if these features were added:
a) Persistent connection points for paths and shapes so that moving around a shape that has a path attached to it doesn’t affect the connection points (i.e., lines remain attached to the shapes they were originally attached to).
b) Option to create a bigger canvas (so that it spans beyond the viewport of the iPhone) - I like to put quite a few diagrams and notes on one page. As a workaround, I decrease the font size for every new text element, though that would probably make the exported PDF not very legible.
c) Landscape editing would be great (but not that big of a deal)
d) “Hand grabber” tool, so that you can use it to drag the canvas around with one finger, instead of having to use 2 fingers, since sometimes the zoom level changes as a side effect. This would be especially helpful if you implement my second suggestion (the ability to use a bigger canvas).
e) More UML shapes (though most basic shapes are here the “actor” (stick figure) shape is an important one). Although it’s not hard for people to create their own shape library (great feature, BTW), it would be even easier if these shapes were included.
Your app, though, is by far the most useful, flexible, and easy-to-use diagram app in the store right now, and well worth the 8 bucks. I can tell you devoted energy towards making this app usable and intuitive (which is more than I can say for the majority of iPhone apps). Thanks for making it!
Dallas
Intaglio mailing list
