Mr_worm1
(Mr worm)
April 19, 2011, 8:52am
#1
Hi,
When trying to publish my site I keep getting javascript error on my favicon action and even on my webyep 0 init code page action.
What’s the best solution.
Delete action from page publish - save.
re-apply action and publish!
Or delete actions from system and re-install!!
Many thanks
Worm
Joe2
(Joe)
April 19, 2011, 9:32am
#2
It sounds like one or more of your Actions is changing/adding code back to Freeway incorrectly. What do the errors say?
On 19 Apr 2011, at 09:52, Mr worm wrote:
Hi,
Many thanks
Worm
Mr_worm1
(Mr worm)
April 27, 2011, 9:04pm
#3
Hi Joe,
I get a message saying “there was an error detected in the javascript of the action Favicon” with a red ! symbol.
If I clear the error, i get another prompt.
Javascript error - action “favicon” - fwParameters[“AnimatedIcon”] has no properties
I get the same errors for the Webyep: 1 init Code joe??
What would you or any other guru suggest is the best course of action in which to proceed and resolve the errors!
many thanks
Worm
Tim3
(Tim)
April 28, 2011, 8:34am
#4
Do you have any other actions applied to that page or a folder action applied to a parent folder at all? It sounds like the action is assuming there something is there that is getting removed.
If you want to send me a sample Freeway file than shows the problem you are having I’ll take a closer look at it for you.
FreewayActions.com - Freeware and commercial actions for Freeway Express & Pro.
http://www.freewayactions.com
Mr_worm1
(Mr worm)
May 1, 2011, 3:11pm
#5
Hi Tim,
what email address can I send it too please?
Worm
Tim3
(Tim)
May 3, 2011, 8:56am
#6
I’ve CC’d you on this reply so you should be able to see my email address and reply directly to me. Alternatively try tim @ the domain listed in my signature below.
Mr_worm1
(Mr worm)
May 3, 2011, 3:08pm
#7
Will do, thanks Tim
Mr_worm1
(Mr worm)
May 10, 2011, 11:53am
#8
Did you get my files Tim? I have mailed you…on tim @ the domain listed in your signature
Regards
Tim3
(Tim)
May 10, 2011, 11:55am
#9
For some reason I didn’t get your files. Please resend them and I’ll take a look this evening.
