Joomla Actions Suite for Freeway 7.0.1
Hello, I would like to know if anyone used “Joomla Actions Suite” by Paul Dunning ?
http://www.actionsworld.com/Actions/joomla/index.php
If so, can you tell me if this extension is compatible with Freeway 7.0.1? I intend to use “Joomla Actions Suite” with Joomla 3.3.
I made the same request to Paul Dunning by email, but I do not have an answer yet.
Many Thanks
Auguste
Hi,
you should be OK - but I’ve not had much time of late to test these Actions against Joomla 3.3
Thank you Paul, I will work with Freeway 7.0.1 and Joomla 3.3.6. I hope the breaking point in Freeway 7.0.1 are compatible with Joomla for a website “responsive” :wink:
Have nice day !
Christophe
PS :Your text is not updated on the site http://actionsforge.com/actions?q=joomla
The advice given by Paul Dunning creator of " Joomla Actions Suite" :
The Actions were written at a time when things like the Relative Page Layout Action were not around, and the best way to use them was wholly inline - so they should work. The Actions provide a template - any content you put in Joomla that is not responsive (images, galleries, etc) will break any responsive behaviour that you have carefully crafted in Freeway.
If you are pouring content from databases or a CMS into a responsive Freeway layout, then you really must work almost exclusively inline in Freeway - some refer to this as the “box model”. If you don’t work like this, then you may find content overlapping other content.
