This is it before I added anything but with the new data-large
dynamo mailing list
dynamo mailing list
Okay, now please tell me what you’re trying to do with the value of
data-large, at the moment of the click or after. Remember, this
attribute is there in the page, but nothing is currently being done
with it until the preview image is clicked. If you click the preview
image, you can access the value of this attribute from inside the
click event handler. Here’s an example, not a rewrite of your code.
Please let me know if it makes sense.
<div id="main">
<img src="first_image_medium.jpeg" />
</div>
<div id="previews">
<img src="first_image_small.jpeg" data-large="first_image.jpeg" />
<img src="second_image_small.jpeg" data-large="second_image.jpeg" />
<img src="third_image_small.jpeg" data-large="third_image.jpeg" />
</div>
This HTML represents the state of the page when it first loads. The
first thing that happens is that the main image needs to be wrapped in
a link so that the lightbox stuff will work. This happens in a first
pass, and it never gets done again as long as the page is loaded. (All
the rest of these code blocks should be taken as being inside a script
block tag – they are all separate parts here, but they are meant to
work together.)
var a = new Element('a',{href:'#',rel:'lightbox'});
$('main').down('img').wrap(a);
//remember, we now have a reference to 'a', and we will use it later
Next, the href attribute of the ‘a’ needs to be set to the value of
the first image, and the first image preview needs to be set to the
“here” class so it gets marked as current.
a.href = $$('#previews
img').first().addClassName('here').readAttribute('data-large');
That’s all the setup. The data-large value is now moved into the href
attribute of the link we wrapped around the main image. This sets the
stage for the lightbox script to pick up that href and use it as the
src of the giant image. If you wanted to intercept that value at this
stage, you could do so in the previous block of script. For example,
if you wanted to maintain a global reference to the current data-large
value, you could rewrite that previous line to read:
var current = $$('#previews
a.href = current;
Now the variable ‘current’ holds the data-large from the first image.
Each time you click on the previews, you have to change this at the
same time that you change the a.href AND the img.src of the large image.
Now we just listen for clicks on the preview images, and use that to
drive the rest:
$('previews').observe('click',function(evt){
var elm = evt.findElement('img');
if(elm){
$$('img.here').invoke('removeClassName','here');
elm.addClassName('here');
current = elm.readAttribute('data-large');
a.href = current;
$('main').down('img').src = elm.src.gsub(/_small/,'_medium');
So if the click lands on a preview image, do the following:
Now, at any point after this, if you need to know the value of the
data-large associated with the currently-shown image, you have it in
the global variable ‘current’ and can read it from there.
dynamo mailing list
dynamo mailing list
data-large is just the url to a jpg image. It should be the url for the var original that is in the code now
var original = img.src.gsub(/(/cache|-400x500)/,‘’);
Adam
dynamo mailing list
I read what you wanted again, data-large is the url of the original image, now with watermark. It is the url to the image that pops up when you click the main page imagethat uses lightbox.
Adam
dynamo mailing list
I understand that. I’m afraid I’ve completely lost the thread of what you’re trying to accomplish, then. If you go through the steps above, I’m hoping you’ll understand what is happening when. If you can step through the code as I have done, perhaps the answer will be clear to you.
Or, if you could write a prose story that describes what you’re trying to accomplish, leaving the EE and EE Image Helper entirely out of that story, talking only about what is in the page when the browser loads it, then I may be able to help you further. Remember – JS and EE have nothing at all to do with one another. The most they can do for one another is leave notes on the fridge (in this case, the DOM of the page).
dynamo mailing list
I tried incorporating your new code into the old script Walter but I think I messed it up. The old script worked fine I just wanted the url value of data-large to replace the var original value when a small image is clicked, thats it everything else worked brilliantly.
Adam
dynamo mailing list
That code wasn’t for using, it was for looking at a step at a time so
you could see how it worked. That’s the key. The existing code would
tell you what you needed to know, but you had to know where and when
to ask it.
small image is clicked, thats it everything else worked brilliantly.Adam
dynamo mailing list
dynamo mailing list
I didnt write the original code Walter I think I understand what you sent me but am not 100% sure what everything does in the original code and what I need to replace or is no longer used. For instance is var original still needed? It looks to me it isnt,
Adam
dynamo mailing list
In the latest “original code” version, the var original value is used on line 63 to set the value of the lightbox link after a click on one of the preview divs. It sets it to the src of that preview div’s image, after using gsub (a Prototype-enhanced form of the native String.replace() function) to strip out the cache and geometry values from the filename.
Basically, this does the same thing as this line in my example:
But the more I look at it, the more I realize that there’s vestiges of two separate attempts in here, and you’re only needing the last of them. This very brief JS should completely replace your earlier effort, and it should just work.
dynamo mailing list
If you’re looking at the gist right now, I just changed it to fix one
problem I spotted.
dynamo mailing list
Thats brilliant Walter and so much shorter. Now I dont get it at all. Well I get some of it but where in that script is the image swap? Its obviously there as the images do swap.
Thank you so much Walter, just brilliant.
Adam
dynamo mailing list
Line 15 is the entire image swap thing.
dynamo mailing list
Thanks Walter i’ll study it. Is there any documentation online or otherwise that I can look at to help understand the language a little better?
regards
Adam
dynamo mailing list
Douglas Crockford has written a very useful book called “JavaScript –
The Good Parts”. I also use the O’Reilly phone-directory-sized
“JavaScript: The Complete Reference” a fair bit.
little better?regards
Adam
dynamo mailing list
dynamo mailing list
So is it Javascript w are using here sorry to be dumb but I see protaculous, javasript and jquery I dont know what the difference is.
On a separate note Im not sure if its you that made this forum Walter but is it possible on the forum reply email notification to have an anchor that takes you to the end of the thread rather than the top of the page I can imaging there are threads much longer than ours
regards
Adam
dynamo mailing list
JavaScript is a programming language. Prototype and Scriptaculous and
jQuery are programming ‘toolkits’ written in JavaScript. Prototype and
Scriptaculous are known in jest as “Protaculous” because they travel
together (it’s impossible to use Scriptaculous without loading
Prototype first). My Protaculous Action is a way to use these two
libraries in Freeway without a lot of heartache.
If you want to understand JavaScript, it’s essential to learn the
language before you learn any of the toolkits. Once you have a basic
grounding in how to string together a function and call it, what a
variable is (and particularly how variable scope works), you will be
ready to attack the really vertical part of the learning curve.
Both Prototype and jQuery attempt to smooth over the differences
between the various browsers’ implementations of the JavaScript
language. In addition, they each provide tools to the developer that
aim to make common tasks effortless and fast to code, and optimal for
the browser to run without ambiguity.
ours
Easily done, you should see it in this “ping”. This duplicates the
green button at the top of the page on the site, which tells you the
number of replies.
dynamo mailing list
Thanks Walter that was really informative. Ive never really delved into Javascript too much, i’ll grab one of those books and have a look.
Yes thats what I meant about the anchor much better. Was that a setting I missed or have you just added it?
kind regards
Adam
dynamo mailing list
look.
Just added it. No idea how that will work for pages that have short
threads, but we shall see.
dynamo mailing list
