Try this little exercise for a simple gallery like the one at:
http://www.shopaint.co.uk/shopaintcustomer.html
1 - For your large images, import the first one into a graphic box
and give it the Action Target Show/Hide Layer and set the parameters
to Initially: Hidden, Restore: Sticky, Effect: Fade. I use a Duration
of 0.8, but you can experiment to find what you prefer. Leave the
Target Group at Indigo and set the Target #: 1.
2 - Duplicate this image in the same position, double click on it to
bring up the Graphic dialog and locate the next image (re-scaling if
necessary). change the Target # to 2. Repeat for each new image,
incrementing the Target # each time, to build a stack of main images.
3 - For the thumbnail images, import into graphic boxes and give each
the Rollover Action setting the parameters for Mouseover: Item and
Target # to match the main image Target#.
4 - For a short cut, duplicate the first thumbnail the number of times
you need - spaced at regular intervals - and then double click on each
to locate a new image and change the Target#.
(You can also make thumbnails individually by copying and resizing/
resampling the main image before you apply the Action).
Once you are happy with your page you can always duplicate it and just
change the pictures for another gallery. Use the Site Panel to select
each layer and go to the Item Menu - Modify - Locate, to change the
main images. Just double click on the thumbnails to do the same.
You can also use a double image and/or Click on the thumbnail, so that
it changes colour or fades when selected
Be brave - experiment. That’s how you really learn Freeway.
Colin
On 26 Mar 2009, at 19:54, riccc123 wrote:
I’ve been trying to get my head around the targetshow/hidelayer
action as this seems likely to help. I’m finding it hard- any tips?
Thanks again!
