Lightroom & Freeway Pro
Hi,
I have recently created a web gallery in lightroom & would like to know how I can incorporate this in to a freeway pro site?
I have seen similar threads on this subject (with slideshow pro) but can’t seem to get the settings to work.
Are you using SSP with Lightroom or exporting a slideshow from Lightroom that is non-SSP related?
If SSP then look here:
http://tinyurl.com/fwtuts
Then scroll down till you see the one’s about Lightroom and SSP and Freeway. Those should be easy enough.
If else, I’m not sure you can “build” them in Freeway. Perhaps someone who has or would know would chime in.
Good luck.
Thanks, not using SSP. Just the web page in lightroom to create a gallery.
If I try put the swf file as a html object in freeway then prewiew in browser I get the flash page half loading but it sticks. (I also imported the folder to my server via FTP)
Not really sure what to try. Others seem to be using SSP.
on 24/05/2009 23:43, chris at email@hidden wrote:
Hi,
Hi Chris,
The galleries on this site were created in Lightroom and dropped into a
graphic frame on the FW page:
http://dantucker.co.uk
With the help of the “Web module” using Airtight SimpleViewer, part of
Lightroom, and the paid for “SimpleViewer-Pro” which allows customisation of
the galleries for your needs. It’s not cheap at $45, but it does work.
More info here:
http://www.airtightinteractive.com/simpleviewer/
http://www.airtightinteractive.com/simpleviewer/pro/
Best wishes Peter
Peter Tucker, Oxford UK email@hidden
Hi Peter,
I upload into the web tab to a new created map into my domain; ( httpdocs in my case or in the Gallery ) that i named gallery.
there i upload the stuff into and back in my site i create a external link; as like this example
( http://www.artofmakeup.nl/gallery/varendcorso/index.html)
That way i can make as many gallerys as i like.
hope you find this usefull.
regards
Eugenie
on 27/05/2009 21:09, eus at email@hidden wrote:
Hi Peter,
like this example
regards
Cheers Eugenie,
Thanks for the suggestion.
Best wishes Peter
