linking external folder help
I am doing something wrong in trying to link to my web portfolio folder (that contains an index.html). I have made the external link /portfolio and then /www.yosemitecollection/portfolio but can’t seem to make it work. My portfolio folders are located in the home directory of my host. What am I doing to make linking to my html portfolios so difficult?
So you have the folder called portfolio in the home directory… so
the link you have as:
www.yosemitecollection/portfolio/
should also have a .com or other… no?
thwn rather than starting your link as: /www.yose…
set it as: http://www.yosemitecollection.com/portfolio/
/portfolio/ should also work.
Hope this helps
I should add to this that the above is if the page you are linking
from is also in the same folder of the same domain.
Hi all,
It’s been solved, it was a Freeway FTP problem. Joe at Softpress
told me I needed to put my ‘public’ folder as it is written on the
server in the Directory field. Hey Presto! Site up and running just
the way I wanted.
Must do some more updating to keep my hand in as I love using Freeway.
A huge Thank You to all who laboured over this with me.
Carolyn
Congratulations. Now a prayer for cold weather presumably…
Pete
On 3 Dec 2007, at 19:03, CarolynBarnett wrote:
Hi all,
the way I wanted.
Carolyn
Don’t worry Pete, it’s been snowing here for days. Just did a couple
of tweaks on my site and the upload went smooooothly and site A OK!
Whew!
Carolyn
Pete
Hi all,
the way I wanted.
Freeway.
Carolyn
I now have a similar problem as Carolyn. I can now upload my files to www.yosemitecollection.com but I now need them to be placed in my public_html folder. Now when I set /public_html as my directory I get a ftp error?.
Try leaving the / off of the path. Just put public_html in the
directory field.
Very likely, you are asking the server to put your files in a non-
existent folder at its very filesystem root:
/public_html
rather than in “your” public_html, which is probably somewhere like
this:
/home/users/yourname/public_html
If you leave the initial slash off the address, then the server will
(most likely) work out which public_html folder you mean by virtue of
your login credentials.
I get a ftp error?.
