links through layers
I am redesigning my site
I am using a ‘postcard’ sized background so am using a scrolling field for most of my text areas.
I also have pop up graphic fields that sometimes obscure the text - ie their layer is on top.
I have some inline links in my text - this all worked well before in a normal html layer. Once the graphic disappered you could still click the link in the text,
Since changing to scrolling fields I can either have the graphic on top layer which works fine except once i lose the graphic, the text field underneath is not active and you can’t click links.
Alternatively I can place the scrolling field at top layer but the text is then placed in the graphic display.
I haven’t explained it well but if anyone knows what I mean I would appreciate some help.
Is there some way of keeping the scrolling text the active layer all the time?
dynamo mailing list
