MacBook Pro Fan Noise
Hi Rocky,
I haven’t actually experianced any noise problem with the MBP I have, it is on 98% of the time and I use it every day on my lap usually. It does get hot but not as much as my powerbook that I had before this. We get temperatures in the mid to high 40’s in the summer, I do notice the fan kick in then and also anytime I use Parallels but under normal circumstances I don’t have a problem.
Might be worth your while to pop over to the Apple discussion list and see what comments there are there on this:
http://discussions.apple.com/search.jspa?objID=c190&search=Go&q=noisy+fan
HTH
Mike
