MagicZoom and Freeway
Hi all,
Has anyone successfully implemented the excellent image zoom utility called MagicZoom into a Freeway document?
I am just about there, but unfortunately I can’t get the “Loading image…” animated gif to show while the images load in the background.
I have contacted the support for the software at Magic Toolbox, and they have been very good in trying to get me up and running for several different uses, but they have commented that the code being produced by my Freeway document - using markup items - is messy and they can’t make any promises.
Jonathan
I will answer my own question on this. It appears there is an error somewhere in the files supplied with the application, and those at Magic Toolbox are on the case.
I haven’t even purchased anything from them yet, but this is the second time they have given full technical support on their demo software and I can thoroughly recommend them as a company.
Jonathan
Keep us posted, I have looked at MagicZoom before but never used it.
Cheers, Marcel
