Major image upload problems!
Hi Freeway talk,
Been trying to update my site, what started out as just adding a new button on my menu has turned into a freeway nightmare.
All the buttons on my site have disappeared, whereas they work perfectly in the preview in freeway.
If the missing images are right clicked on and the link copied, it points to a Work/Resources folder, but the images still don’t show. Going to the destination given through my FTP shows that the images are there, just not being displayed.
The site in question is http://www.mrwillvincent.co.uk
Oddly enough, when one of the work pages is being viewed, all the buttons show correctly. - http://www.mrwillvincent.co.uk/work/everythingisatool.html - for example
Anyone got any ideas whatsoever? Bit desperate here!
Thanks in advance,
Will.
The web address of the missing image(s) is http://www.mrwillvincent.co.uk/Work/Resources/Shop1.jpg but the pages with the correct images are at http://www.mrwillvincent.co.uk/work/
Note the first has an UpperCase W the second LowerCase w
How are you uploading your site - it would be very strange for FW to get this wrong.
If you are using FW to upload then I suggest you Edit>Resources and Resample all and do a fresh upload. If not then I suggest you may have more than 1 folder on your server Work/work
Hi Dave,
Cheers for the reply.
Re-sampled and re-uploaded, no change.
Am using FW to upload.
  • MID POST EDIT! -
Just saw that on freeway my ‘work’ folder had a little w. Changed it to a big one and hey presto.
God bless the intricacies of computing devices.
Many thanks,
Will.
