Good morning, I figured out what I want to do with this jewelry website.
I want to have an appearance Kind of like tiffanys.
I am guessing that when you rollover the picture and get another “pop up” that is the rollover action.
now how to do the menu drop down (choices ) like seen on this page and have the main image flip to another that you can then rollover: can I do this in FW
You are using images with a bad anti-alias setting on your graphic text - that is why it is difficult to read. I think you are anti-aliased against a white BG instead of the pale green.
ah ok I will go into PSD and make it the pale green.
I made those in FW and exported.
Thanks - should I make the words a different color?
J
On Aug 30, 2011, at 8:06 PM, DeltaDave wrote:
how do I make the words be clearer / readable
Ok, got that all fixed. Here is one last question (i think)
I am using the transition FX… awesome.
If I want an image to appear on load, then fade away to show another on load… etc x 4 then have the whole group load back in ( I would use the transition FX for the last part i think)
How would I load one fade etc…?
Thank you again
J
J
