master setting
why master setting uncheck to many times when i working in page.?
This is very frustrating.
I’ve read the post a couple of times but I give up. Absolutely no clue what you’re trying to say or ask. Can you try again please? I’m happy to help you out, but I need to understand the question first :slight_smile:
Richard
The connection between a master and its children depends to a great degree on the children remaining unchanged copies of the master. When you introduce changes to the children, they can easily become detached from their master, either entirely or partially. There has been a lot of work in this area in recent versions of Freeway, to make the connection more robust. Certainly you could expect that if you edit the content of a master item, the Use Master Content would become unchecked, right?
Thans Waltd… But this update of fw is very confused.
