Measurements vs. Dimensions
What is the essential difference between the Measurements and. Dimensions panes of the inspector.
Specifcally:
  1. as it relates to having a minimum page height of 100%
  2. as it relates to Master pages—it doesn’t seem possible to control all page height to 100% from a master page.
I assume that you are after a specific page-construction, so an answer is pretty tricky.
Let me say it that way:
Dimension:
Absolute values for width and height (200px 400px).
Measurements
Usually relative, so neither a width nor height defined or if, the values are percentage (25% no height).
Measurements only make sense if you place items relative (inflow or box-in-box), while dimensions are usually used by placing items absolute (drop and drag). Relative positioned items can’t be dragged.
The “page-height” is Freeway specific - cause a page basically doesn’t have a real canvas (as we are used to). If it has - you have to define it. The magic is a random item (called #PageDiv).
Just as a start of the discussion - be more specific of your desired result.
Okay—first question would be:
I have an Inline layout with Page Dimensions set to 100% page height and 100% minimum page height.
In this case, does it matter what my page SIZE is in the Measurements panel?
No it doesn’t cause the height is steered by its content - that’s the real value of inline-design (at least to me).
Understood about page SIZE but does that only apply to height? If so why does page WIDTH is a have an effect?
In my world, neither width and height (Freeway’s workspace canvas spoken) really matters. I set the page-width in Freeway to 1823px (never do this in drop and drag mode) in the “measurements” and the height to something.
So I simulate the “browserwindow-width” of a medium sized monitor (21"). All placed items are in percentage values width and flexible heights).
Doing this, “dimensions” are greyed out in the inspector which will mean, that the initial “#PageDiv” doesn’t have the width and height properties declared and can therefor grow with its content.
All the rest is part of my concept “Box-in-Box-Model FreewayPro”, developed, screencasted and shared in “The Lounge” for some bucks.
… and after reviewing the above (and head scratching how to best explain - gosh) I came up to the following:
MEASUREMENTS:
Are describing the situation within your Freeway-doc and are responsible for the WYSIWYG experience. This is the first choice in absolute positioned layouts.
DIMENSIONS
Is the truth in the browser - or the properties finally executed and manifested in the source code.
In absolute positioned layouts measurements and dimensions are (mostly) the same values while in a relative layout measurements are turned into other values (mostly) or are even not declared.
Thanks Thomas. One other difference is that one includes any padding and the other doesn’t.
Both have padding and margin fields/pull down menus, but the Dimensions pane offers an option to customize the left, right, top and bottom sides. I find this very handy.
Right, I meant the value in the Dimension pane is less any padding, whereas the value in the Measurement pane is greater by the amount of the padding.
Ahhh, yes…understood. Thanks for the clarification.
This is called box-sizing and means:
In the Freeway surrounding, box-width + padding + border requires more space and is therefor added.
In the dimension (traditional box-model don’t mix with Freeway’s box-in-box model) the width of this box is reduced by padding and border) so width - padding - (border).
So Freeway has to do a lot of compromises (display and publishing).
If you once stumble upon box-sizing: border-box you theoretically know now what and why it is:
http://www.kimmich-digitalmedia.com/articles/box-sizing-border-box
Thanks for posting the above info and your link, Thomas. I use box-sizing, and it’s always good to understand what’s going on under the hood/in the background.
