Menu 'hamburger' does not work on one page
I have a CSS menu on the Master Page and it works perfectly on every page except one. On that page the links work when the page is full size but the hamburger links do not work for all other sizes. This action works on all the pages except activities-clubs. Probably something simple but would appreciate any help.
http://dinnerafter5.com/activities/activities-clubs.html
Did you try deleting everything on the sub-page involving the menu and then use “Reapply Master”? Sometimes an individual page will have elements which may be unnecessary, redundant or have older copies of things lurking around. “Cleaning out” the items which are supposed to be provided by the Master Page may resolve the issue.
Make sure you’ve backed up your work as a separate version before proceeding.
You even don’t have to delete the content, just walk through all items on the page which are derived from the master. Select them one by one, and make sure the Inspector has the ‘Use Master settings’ option selected.
Richard
Thank you for the suggestions. I had already tried the second one so tried “Reapply Master” but it didn’t work. I remade the whole page and tested it as I went along to figure out what was causing problem. It was at the very bottom of the page where I had a 'link to new window" action that was preventing the ‘hamburger’ from opening. I just made it a simple link and the hamburger magically opened.
Another instance where it sounds like a javascript conflict.
