Menu/List help!?
Hi all, just putting together a shop site and using the Paypal action which works fine, I am just having problems with the Menu/List for the sizes S/M/L?? how do I get these to work with the paypal.
I have included a link, any help would be appreciated.
Regards Dec
http://www.designedatme.co.uk/LMHR%20SITE/SHOP/index.html
This page http://www.deltadesign.co/odds/tartan.html
Uses the E-buy Form action in conjunction with the E-buy product Variation action(s)
This works fine when the different sizes (in your case) are the same price.
Thanks DeltaDave
I will give this a try, I presume this will work with the Paypal button actions…
Declan
Hi David
I don’t seem to have the E-Buy Form action? I have the E-buy text action and review action…but non of the two you mention.
Confused
Hello again David, sorry for going back and forth, solved the E-variation action but I then hit upon this;
“Cannot use this action - You must apply the action “E-Shop settings” action a folder that contains this page”
I have attempted to apply the action to the folder but these are all grayed out in the ‘Item’ menu?
Any help would be appreciated.
Declan
Well this solution is really for using Mal’s for cart processing - it may well not be the way to go if you are going straight to PP.
In that case I would suggest you use PP’s online Add to Cart button builder that will give you the size variation options which I don’t think are available through the PP Button action.
Thanks, I will give it a go.
Your help is much appreciated.
In PP My Account>Profile>Selling Preferences>Manage my payment buttons>Create new button
There you can make new buttons with variation options and save them/edit them.
Thanks again…
:wink:
Heres one I made earlier…http://deltadesign.co/fw_examples/pp_button.html
