Hi, David:
Thanks so much for taking the time to outline all of this for me. I learned a lot from it.
Yes, I was using FW’s built-in upload facility and it was to a mobile me account.
As it turns out, after I checked the the organization of all the FW files and checked the resources, everything seemed to be organized correctly and there wasn’t any file missing. I was at a complete loss after spending a lot of time doing this. And everything showed correctly in the browser running off my hard drive – there was no trouble in publishing there, only when I tried to upload.
The only thing I was then able to think of was that maybe the error message didn’t really reflect what was wrong (I was thinking desperately) and that maybe I had somehow messed up the login information for my mobile me site. I reentered it all and still no joy.
So I decided to try to upload it to another domain I had with a different hosting service. And . . . everything uploaded perfectly with no errors and the site showed perfectly online in the browser.
Seems very strange to me, and I still want to try and figure out why I can’t upload to the mobile me site. But at least I can get the site uploaded so that my friend for whom I’m doing the site can review it. Ultimately we’ll be switching to a different host anyway (have-host.com, which you recommended).
While checking the organizational structure, I did wonder about something. What’s the difference between the contents of Resources Folder in the Sites Folder and what you see when you choose Edit Menu > Resources? In the Edit Menu > Resources, all I saw was all the jpg’s I have in the Media folder while in the Sites Folder > Resources Folder there were some gif’s that go on the pages plus jpg’s.
At any rate, thanks again for your help.
Martin,
Signal Mountain, TN
On Jan 1, 2011, at 7:56 PM, DeltaDave wrote:
Hi Martin
Are you using FW’s built in upload facility for this? And presumably to a mobile me account.
Firstly what you should do is organise all your FW and associated files into one place.
If you used one of FW’s own staring points then it would have created the following file structure for you.
A your website folder
Inside that a yourwebsite.freeway document, yourwebsite.fwbackup, Media folder and a Site Folder.
The site folder contains all the files that will be copied/uploaded to the server.
Select yourwebsite.freeway document and open it with FW. Once you have it open then Go to the Edit Menu>Resources. The dialogue box that opens will give the status of all the Pics etc that you have used in the file. If you have any that have a status of missing then select the file and use the Edit button down the bottom right to locate the missing file. Do that for all missing files. It is a good idea if you know what images you have used in your pages that you copy them to the Media folder that FW created for you within your Website folder.
If you didnt use any of FW’s starting points then it is a good idea to create that Media folder alongside your FW doc and its site folder (all enclosed in a Project folder ‘my website’)
Once you have ‘found’ your missing pics then Publish your site (or just Preview all your pages) to update the contents of the Site Folder.
Once you have done all that then you should be able to upload normally.
