You must put your template in the “Template” folder of Joomla 2.5 … Then you must click on “Update” and “Discover”. When you create pages with Freeway Pro you must point to the folder “Template” of Joomla…I hope this will help you
Ok how do do the template… Do you just save or export? Do you zip file which folder?
Sent from my iPhone
Must be exported directly into the “Templates” folder of Joomla. It is not necessary to zip… Dont forget to change the name of the file in the inspector palette “index.html” in “index.php” !
So when in freeway - do I save as template? what do we do with the site folder?
then upload that template to the template folder?
Im not trying to sound stupid… just it is not clear…
thanks!
You are not stupid it is natural to want to understand. In Freeway Pro when you create new document this one must point to the folder “Templates” of Joomla. The “Freeway site folder” must be in the folder “Templates” …
Have you seen the “Freeway sample file” from Paul Dunning? It is normaly in the ZIP file of this action …
Ok, yes I have it open… but the templates folder of joomla is on line… so after creating and saving or save as template - I move both site site folder and the FW doc to the on line joomla folder template?
or
or how do you point it to an on line folder?
On Feb 21, 2013, at 8:30 AM, Julie Maxwell email@hidden wrote:
Thank you…
or
ok - so if I can’t develop off line - I then move the image folder (not the site folder) and the index.php page…
I have mamp on my mac but unsure how to install joomla on it…
also - if I read correctly at some point (not in this thread) If going from my mac - I should do a full install of joomla on there with the template? or can I leave joomla installed on the server / domain
I really want to learn all of this… but having a time getting my arms around it…
On Feb 21, 2013, at 8:50 AM, Auguste email@hidden wrote:
Just move the site folder (“image” folder + “index.php”) in “templates” not the Freeway doc “yoursite.freeway”
I did find youtube videos - off to watch and learn…
thank you again…
