Another bit of icing for the cake. If you want to add your Skype or
AIM or similar addresses to your contact info, you can use the
following microformats to do this:
- aim:yourScreenName
- ymsgr:yourFriendName
- msnim:email@hidden
- xmpp:email@hidden
- skype:SkypeName (works for call only, not chat)
If you use the bulleted list format as I have done above, everything
will be laid out nicely for you.
Once you have finished, check how it gets reformatted by searching
for yourself and viewing your public page.
