Minimum Height- a nuts and bolts how-to
Hi folks,
I read in some prior posts about using the extended dialog to set minimum heights (and widths) for divs, but it never really explained exactly how to do that.
Could someone chime in with a quick how-to?
thanks,
Andrew.
If you select a div (html box) then go to the item > extended > div
style
And add :
value: 200px
You box will stay at a minimum of 200px high when published. Modern
browsers should respect this. Old ones won’t.
Similar effect goes for:
*Would’nt it be great if Freeway Pro could list in the program some of
the CSS styles possible like Xyle Scope or CSS edit rather than have
to hunt down these elsewhere.
One for Freeway Pro 6 maybe?
David Owen :: Freeway Friendly Web hosting and Domains ::
http://www.ineedwebhosting.co.uk :: I Need Web Hosting Mac friendly web hosting and domain registration
:: http://www.PrintlineAdvertising.co.uk
On 29 Apr 2009, at 15:46, Andrew Macris wrote:
Hi folks,
thanks,
Andrew.
Or perhaps another level. Freeway Pro Advanced?
I think if Freeway Pro wants to be respected as a Professional product
it should look at doing something like this.
That works great. Thanks!
So what other useful things can we plug into this box?
Andrew.
