mobile phone viewing problem
I have produced the above site with responsive breaks for all the standard tabs freeway show (320, 480 etc) all of which look fine when I preview and also if I view on a mac and reduce the window accordingly.
However, viewing on an actual smart phone the footer section is all over the place???
www.church-court.co.uk
… all of which look fine when I preview
Really? It’s a mess in every browser, so no wonder if it screws up on a smart-phone:
I can’t help you here in detail, but two things are simply forbidden if it comes to “responsiveness”:
Fixed widths* and absolute positioning* as long as they cause “side-scroll”.
(*) Sidenote:
Both methods are fine as long as you know what you’re doing.
I can see that the logo in the footer is set to absolute but if I change it to ‘fixed in window’ it jumps to the top left of the page?
Did you build this from scratch?
If - you should be used to the term of placing items relative - or inflow if you want. This method - flexible widths given ensures, to avoid overflow → side-scrolling → mess-up of partials.
It’s a simple matter of fact, that you have to re-structure your footer, thinking about a three col design such as the content above.
Thanks Thomas, I will do that
Ian
