Hello everyone!
How can I make a CSS menu with the moo effect on load to make a sliding door menu that opens and closes when you hover or click with the mouse?
Not a rise, but moving from left to right
thanks in advance,
Marcus
To be more specific I think what I need is the mootolls accordion but instead of make it move up and down, to make it move left-right. Is that possible with mootolls or I should go with something else?
thanks
Marcus
I know Dan Jasker has a screencast about Jquery…Would Jquery be the way for having these sliding tabs? Any ideas?
Thank You!
M
waltd
(Walter Davis)
February 16, 2011, 5:22pm
4
You can do this with ScriptyAccordion, but you cannot have any Moo-
based effects on the same page. Horizontal accordions are more limited
in their design possibilities than vertical ones, but mostly that’s to
do with the types of content you can use as your headers (think
images) than anything else.
thanks
Marcus
Thank You Walter!
I knew you had the ScriptyLightbox and I’ve downloaded it but didn’t know about this one…nice
I got it now and read the New Horizontal Accordion Feature and downloaded the example also. I’ll be working on this soon.
Thanks again, Walter!
Marcus
Hi Marcus
Have a look at this one and see if it is of any interest http://www.deltadesign.co/menu_stuff/menu_slider.html
Hello David! Oh Yes! I love this effect and think I could use it. How did you do it? With the scriptyaccordion?
Thank you!
Marcus
Sent from my iPhone
On Feb 16, 2011, at 7:17 PM, “DeltaDave” email@hidden wrote:
Hi Marcus
No - no actions I am afraid.
There is a bit of code markup and an external stylesheet involved so you will require some understanding of CSS.
I will try and put together a ‘How To’ for you if the code bit doesn’t put you off!
Hi David,
Thank you! I’d really appreciated. I am working on a website to a client that repairs and installs sliding doors and these ideas are coming to my mind…
Best,
Marcus
Marcus if you visit my example page you can download the FW5.5 file
Thank You, David!
Marcus
