more carousel questions
hey, newbie here…
I have a couple of questions, trying to get the just of carousel.
After drawing the inital html box, and inserting a photo into my pane, and duping…I draw two graphics boxes, and import button images, and apply the carousel buttons to it. For some reason when I preview, they don’t do anything. However, if I do tabs, the same way, they work. What am I doing wrong? Also, how do you apply the shake or elastic feel to it?
alanc
btw,
you are supposed to group the buttons with the carousel action correct? I can’t seem to get the buttons and carousel panes to all group together.
alanc
Group the panes together and apply the Carousel action to that group. Draw the buttons and/or tabs, and apply the relevant (button or tab) action to each. Then select everything and group that.
It should all work.
walter
got it! Thanks.
Alanc
