I know you write some great little ( and large perhaps ) actions for which I and we are all very grateful
and for which I have happily sent you some beer tokens in the past
One thing that would be useful if you get time ( which is never easy I know ) would be if each one had just a short description of what they do. might even help generate you some more donations ?
Anonymous and crowbar sound good but I have no idea what they are or do
I have been working for some time now on a way to do that, and more
importantly, to open it up as a service for the entire Action community.
PS:
Anonymous lets you remove the IDs from elements in your Freeway-
drawn site. This is critical if you are using Freeway to create
template “parts”. If you were to loop over a part that had an ID, you
would end up with repeated copies of that ID and your site would be
invalid. (More importantly, any JavaScript trickery you wanted to do
to that page would fail, for the same reason.)
Crowbar lets you add your own code to the beginning or end of a TD
or DIV. As you know, Freeway loves to wrap anything in your page in a
P tag. Which may or may not make any sense for your code. If you were
to put a bit of code into your page that prints back a DIV, you
wouldn’t want it to be wrapped in a P. So Crowbar lets you wedge some
code into the element it is applied to, before Freeway writes anything.
On May 2, 2008, at 12:12 PM, diarbyrag wrote:
Hi Walter,
sounds like you’ve been having fun ( NOT ! )
one thing I have meant to ask for a while…
or do
