more web yeb questions
Amazed myself and got a looping version of web yeb to work - even if it is a bit basic at the moment!
Is this possible to add the yellow background - similar to this example:
http://sergeantdesign.com/junefilms.html
Also - the yellow border on the image doesn’t transfer to the web yeb bit, not sure why. If not a yellow background I might just have a rule between each - how is this done?
Finally, when the future films come to be shown in the coming week they need to be moved to a new page “showing this week” - is it possible for the client to do this.
That’s all for the moment. Many, many thanks
Noel
http://sergeantdesign.com/testing1.php
Hi Noel yes you can colour the background yellow.
Just insert the looped items within a div as inlines and colour that containing div background yellow finally loop the container div.
To add the darker yellow border to the WebYep image all you would need to do is click on the WY image and in the action palette click the IMG tag extended button and write this:
style="border-left:5px solid #ffcb3b"
Actually the easiest way to do the coming week and this week is to have a webyep menu with three or four menu items e.g.
• Showing this week
• Showing next week
• Pending changes (which is set to invisible to general public)
what you then do is when the week commences just change the menu titles so
showing this week is changed to pending changes and made hidden from the general public.
You then change the title of Showing next week to Showing this week and change the old Pending changes to Showing next week and make it visible then finally change the order within the WebYep menu by grabbing and moving them into the correct order.
basically a rolling list which you just amended
if you do it in this sort of way you don’t make dozens of webyep page instances that are just used for a few weeks and discarded. and you are able to create the future movie showing list in advance and have it ready to made visible to the general public.
speak soon max
thanks max - another step closer!
bit stuck on ‘finally loop the container div’
loop end after yellow inline div just creates one yellow box
loop inside yellow div just creates one single yellow column
http://sergeantdesign.com/testing2.php
thanks for your patience, Noel
Hi Noel here is a link to a quick example of a way of looping a box with content within it.
ps if you add another style to the webyep image to giv it some margin to the right then the text won’t be right up against the image:
style="border-left:5px solid #ffcb3b; margin-right:24px;"
https://dl.dropbox.com/u/4274685/FileChute/test.freeway.zip
all the bets max
Once again max, many thanks for your help and patience
http://sergeantdesign.com/testing3.php
Noel
Can I just say that if that is your desired text size then please reconsider as us old gits can’t read 10px text very easily.
Thanks David for your comments. That was next on my list - have changed it to 12pt on actual page.
