Hi guys,
I have a mp4 movie that doesn’t appear if it’s on anything other than a page that has nothing behind it.
I want a sky background behind the movie
I’ve tried it on top of a graphic item and on a html item - nothing. Remove the item it is on top of and it works fine.
Page html5, Freeway Pro6, layered page.
Probably something dead simple I’m missing…
Adding basically as Freeway say, by dragging the mp4 onto the page as a pass through. I’ve tried adding the background later and sending it to the back, but no joy. No Action used.
David,
Here is the quick Freeway doc and the mp4 - see if it happens to you if you don’t mind. I’ve put the movie on twice - once on the background - wont play and the second below the background - does play. Or is it just me?
David,
Thanks for the comeback, but with it changed to Quicktime instead of Movie in the Inspector the animation doesn’t loop even with the options set to no controls, loop etc. But as you can see from the file it works OK as an mp4 as long as it is not on a background…? I need this to constantly loop on loading - no controls.
The animation is converted from a .swf through Handbrake and converted to H.264 codec. Do you think H.265 would work any better?
Thanks for still looking…
Yes it works in Firefox now - I used the same settings, BUT it doesn’t repeat as a Quicktime movie in Chrome for some reason. It comes to the end of the sequence and stops, and the start arrow on the controller appears again. I need it to repeat ad nauseam with no input from the viewer.
Use “Movie” instead of “Quicktime” in the Inspector and it works correctly, but ONLY if there is no background - on the background it does not appear at all.
Weird… can you check in Chrome on your computer - I’m using Version 43.0.2357.65 (64-bit)
