navigation pop up
my navigation pop up appears as a list when published with a grey line down the right hand side, not a drop down list. can anyone help ???
You have drawn your nav popup box too tall.
If you reduce its height to the height of one entry and republish you will be fine.
And remember to put a meaningful name in the option1, option2 etc fields
do you know if you can have sub menus from this pop up… (dont know how to explain it) ie the drop down list displays the options a-e f-m n-q etc then when you hover over one of these a new pop up appears with more selections…
Yes you can - and these can also be made with the menu bar action if I
recall where you make a table on the pasteboard and have the menu items that
will appear on the page - with links etc - which is linked via the action
pallet to a table on the page that displays the headers.
I’m sure its all explained in the documentation once you find where to look
whichever way you go.
all the best
Brian
Tony Farrer said recently:
selections…
Do you know if you can have sub menus from this pop up
Not with the Navigation Pop Up action but as Brian says there are methods to achieve that ie CSS Menu action etc.
Don’t forget - you can have more than one CSS menu on one page and so
you can position one of them in the place reserved for your pop up,
while keeping your main navigation menu at the head or side of your
web design.
This example of a double CSS menu might help: http://www.words-strategies.co.uk/clientspace5/Pressure%20Gauges/gaugeintro.html
To simulate the navigation menu, you would only have one “Main Menu”
entry (say “Please choose…”) and the rest would be two levels of
submenu. I am sure the coding fraternity can come up with something
more elegant, however.
HTH Colin
