I am trying to create hierarchical menu where I can click on the
header Menu bar “Products” (for example) and a list will appear of all
the products, then I can pull down and go to any page. I have read
the Freeway Reference Manual and see that this is possible but I am
very confused how to set this up. Is there any place else I can go
for reference data or download and example to copy the design. Is
there a more complete document on setting up this function. I am
coming over from iWeb to Freeway Pro.
I do not know much about the Freeway support community as I have only
been using the product for 1 week.
Darl
I believe what you are looking for starts on page 108 “css menus”.
I just recently discovered this myself and it works quite well once you understand how to set up the list.
It’s a very basic example of what can be done but if you look at “www.peavinewineandspirits.com” the “specials” menu was done that way.
It was a bit confusing to me at first, but actually very easy.
